INTRODUCTION
Laparoscopic surgery is preferred over open surgery because only a few 3-5 mm incisions are necessary to
complete the operation compared to the traditional 20-30 mm incision. In order to start the laparoscopic
procedure, an insufflator is used to lift the abdominal wall off the internal viscera with an inert gas, such as CO2
thus creating pneumoperitoneum. Once the abdominal cavity is expanded, laparoscopic tools are inserted through
ports, allowing the surgeon to work within the cavity. If the abdominal pressure created by pneumoperitoneum
exceeds 20mmHg, the patient is at risk of suffocation and venous embolism [1]. Suffocation occurs because the
increased pressure prevents the expansion of the diaphragm and lungs, thus preventing the patient from inhaling.
Venous embolism occurs when CO
2 diffuses into unwanted cavities and vessels, creating air bubbles. On the other
hand, if the abdominal pressure is too low, the minimal work space can cause the surgeon to accidently operate on
unintended viscera.
Our solution is to create an automated system so that nurses and surgeons do not have worry about constantly
monitoring abdominal pressure. This allows them to focus on the task at hand and thus improves patient safety. In
addition, our solution can potentially eliminate unneeded staff from the operating room, thus saving the hospital
over head costs associated with each surgery.
EXPERIMENTAL SETUP
A schematic of our system is shown in Figure 1 and consists of the following components:
RESULTS
Prior to completing validation activities, we developed a calibration curve for the pressure sensor using a pressure
cuff to determine the correlation between the output voltage and pressure in mmHg. This curve is shown in Figure
10. To validate the functionality of the system, we simulated both low and high pressure conditions using the
manual interface on the LabVIEW program. We then switched the system to automatic mode and observed the
response. Table 1 shows that the actual results match the expected results for each simulation meaning our project
reached the proposed goal. In addition, the system is reliable because 5 validation trials resulted in low standard
deviations, 0.2 to 0.3 mmHg, for stabilized pressure.
We set acceptance criteria to ensure that the pressure we detected during validation was accurate. We determined
that achieving accuracy to within 10% error of a standalone pressure calibration unit was sufficient to accept the
functionality of the system. Table 2 displays the average of 7 trials of pressure readings from the sensor and the
calibration unit. The error for each validation was less than 5% meaning we satisfied the acceptance criteria. The
data for all 7 trials of validation are shown in Table 3.
DISCUSSION AND CONCLUSIONS
The goal of our project was to design a system that can take accurate measurements of intra-abdominal pressure
during laparoscopic surgery and use these measurements to control insufflation. While we were successfully able
to demonstrate proof of concept, our system needs further improvement before it can be successfully integrated
with laparoscopic surgery.
The main source of error in our system came from the pressure sensor. While we were able to remove most of the
noise from the signal by using a low pass filter, the pressure still varied by about 1mm Hg introducing error in the
system. Any movement in the sensor also introduced measurement errors. This was minimized by ensuring that
the sensor remained stationary during inflation/deflation through proper mounting. Further, the signal obtained
through pressure sensor was in the range of millivolts and had to be amplified by a factor near 40,000 for
conversion to mmHg. This amplification increased the DC offset that had to be then subtracted from the signal in
LabVIEW. Another source of error was the slight leakage of gas from our system which introduced some inherent
variation in our measurements. Our intended pressure range also had to be slightly modified due to system
constraints. For example, pressure less than 3 mmHg was difficult to detect and pressure greater than 27 mmHg
automatically shut off the pressure regulator (insufflator unit).
To improve the system, a more precise measurement system needs to be implemented. A more accurate pressure
sensor could be utilized to give a steadier signal. Further, the solenoid valve was a bit noisy and could be replaced
by a solenoid that operates more smoothly and has smaller excitation /de-excitation times.
APPLICATION
For a beta prototype, a heated and 95% humidified CO
2 system could be introduced. The goal would be to
accurately monitor and stabilize the gas to around 37±0.5ºC and 95±0.5% humidity. This tight control could be
implemented using a similar algorithm as presented in this paper. The improved system would decrease
postoperative pain and risk for the patient [1].
