University: University of Ljubljana, Faculty of Electical Engineering
Team Members (with year of graduation): Luka Kosir (2013)
Faculty Advisers: Rasto Fiser
Email Address:log.luka@gmail.com
Submission Language: English
Computer guided test bench for frequency converter driven electromotors
Description:
The main goal of the project is to establish a test bench for different types of electromotors (inducton, synchronous). Power range of the application is limited with available eqiupment and space. The solution is power efficient due to DC link used to establish power balance between two frequency converters. Data is acquired with power analyzer and torque transducer.
Products
The Challenege
A few challenges motivated me to establish an energy efficient or active test bench for electrical motors:
All demands listed above are practically based on acquiring data, so software must be designed in way that different measurement equipment like power analyzers and acquisition modules can be added to application. We must be able to analyze and demonstrate all acquired results of the test in the same LabView program and export them to .txt file.
The Solution
The applicaton is based on LabView 2012 software which coordiantes acquisition, demonstration and logging of relevant quatities. Software dictates speed or torque references to frequency converters. References are sent in FC Danfoss protocol via RS485 serial port. Because port is not integrated in computer, we used USB to serial port converter. User can set all serial communication properties, addresses of the converters and measurement equipment in first tab of the programm.
Next step is to insert motor parameters like rated power, current, frequency and so on to the converter. All relevant motor properties are send to the converter with a custom made user interface.
When we insert all parameters we have to choose between multiple confugiration modes of brake converter. It is possible to choose between speed open/closed loop configuration or torque confuguration. The choice of user is the base for all other settings in software, for example, if user chooses closed speed configuration, it is necessary to insert properties of an incremental encoder. Although all references are consequently based on speed (rpm). If user chooses torque configuration, then the torque transducer is used like feedback and then we operate with references in Nm. So the basic configuration of our software depends on settings of the frequency converter, all software enviroment is adapted automatically.
We can dictate load manually wiht a knob or just set minimum and maximum load and number of measurement points. Programm will generate references in hexadecimal value. When we hit "Run", the test bench must be synchronized first. The procedure is first to run the motor, wait until the reference is reached (status word of the frequency converter) and then run the active brake with the function "flying start" in converter enabled. At every point, all data is acquired with the USB to GPIB converter with GPIB VISA SubVI. User has a chance to manually log the current valuse with special button.
<Explain how your project works.>hen we
<Explain the benefits using LabVIEW and NI tools.>
<Insert image(s) of project with captions.>
<Insert video here.>
<Attach VI code (optional).>
<Level of completion (beta, alpha, or fully functional)>
<Time to build>
<Additional revisions that could be made>
Attach Poster (30 in. x 38 in.) and LabVIEW Code
<Include captions for all graphics material. Type your photo or graphic caption underneath each graphic using this 10 pt Times New Roman font. Embed all graphics. Remember—you must provide individual electronic files for each graphic you include in your paper. Place photos in text after first reference—you must include a reference to all graphics in the text. Include screen captures if you use National Instruments software products. Screen captures must have a minimum resolution of 72 dpi at 100 percent. All other graphics must have a minimum resolution of 300 dpi.>
Nominate Your Professor (optional)
<Insert nomination. Does your professor use LabVIEW or other National Instruments technology to make learning difficult concepts engaging, interesting, and fun? If so, nominate him/her as an outstanding educator by telling us who they are, what they teach, and how they make learning a better experience for you.>
