Dorm Room DJ
Parts List/Cost
276-1657 Photoresistor from Radioshack: $2.99 for pack of 5
Carboard box (we used a pizza box)
Carboard Circle (we cut out of a pizza box)
Soda Can
Scissors
Duct Tape
Opitcal Encoder Circle (circle.jpg attached)
Total Cost: $2.99
Setup
HW
where R is a resistor with a known value.
Then the resulting voltage between Ai+ and Ai- is equal to 5 * R2 / (R1+R2)
Connect 5V wire to the +5V output pin of myDAQ; GND wire to +5V GND pin; AI+ wire to AI0+ pin; run another wire from GND to the AI0- pin.
2. Mount the cardboard circle in the middle of the box so it'll spin. Glue the circle encoder strip on top of it. Mount the can and photoresistor such that the photoresistor is over the edge of the encoder strip at a height of about 3-5 millimeters.
SW
Explanation
myDAQ's constant 5 volt output goes across a series of a resistor and a photoresistor. Since the value of the resistor is known, we can measure a voltage drop across the photoresistor using an analog voltage input channel of myDAQ. The resistance of the photoresistor will change depending on the intensity of the light it sees. When the disc is rotated, the resistance of the photoresistor will vary, causing the volatege to change. When we detect this change in Labview, we output a random DJ scratch sound effect.
The VI uses two ActiveX controls to play two songs simultaneously using Windows Media Player. The user can change the volume and tempo for each song while being able to control the relative presence of each song with the mixer slider.
ATTACHED: VI Code, Documentation
