Sensor Type: GPS
Manufacture/Model Number: Globalsat: EM-408
Link to Sensor: https://www.sparkfun.com/products/8234
LabVIEW or C: LabVIEW
Version of LV: 2013
Description/Instructions on how to use this example:
This example reads data from GlobalSat EM-408 GPS Sensor, processes the data and displays the data on the waveform chart.
Instructions:
1. Connect sensor to NI myRIO
2. Open .lvproj in .zip attached folder
3. Open and run Main.vi
Wiring Diagram of Sensor to myRIO:
EM-408 myRIO
V+ +3.3V
Gnd Gnd
RX A Connector/TX
TX A Connector/RX
Enable/Disable +3.3V
Code: myRIO GlobalSat EM-408 GPS sensor.zip attached
Hi! It looks like the attached examples and datasheets are for a microphone rather than a GPS sensor. Do you have some code for the GPS sensor that you could post?
Thanks!
-Tim
Hi Tim!
Thank you for catching that! The files have been updated with the GPS Sensor.
-Sunaina
Thanks for the code!. I'm using a GP-635T and your code help me a lot.
Hi Sunaina,
I tried to reuse your code but I couldnt make it work at a baudrate of 9600 bps. I configured it at 4800 bps and it finally worked.
Do you have any idea why?
Thanks for the code, ( before knowing that the robotic toolkit have the "GET GPS DATA.vi" I spent quite a long time developing the same functionality , good to know I can use this VI instead
regards,
Erwin Franz
Erlab
