To learn how to use this component with NI myRIO, download the NI myRIO Project Essentials Guide.
Hi, I’m trying to use a Hall effect sensor to measure the distance of a magnet using the CompactRIO and Labview and I’m not sure how to both set up the sensor with the crio and the code needed in LabView. Any help would be greatly appreciated! Thank you!
what do I have to do fix my labview set up to try to make an output for how far a magnet is from the hall sensor?
