Introduction:
myDCMotorControl is a tutorial that's been developed to help guide students through an introduction to control engineering. Control engineering can be a complex subject, but as it's used in a wide variety of engineering systems, it's a useful skill to know.
The tutorial takes the student through some basic control theory, before giving them the opportunity to experiment and vary parameters to view the effect on the system.
Hardware:
This tutorial uses the myDAQ hardware with an Elenco Protoboard attached.
To build the myDCMotor circuit for this lab, you will need
Using the tutorial:
Use the tabs at the top to navigate through the different pages of the tutorial. When you're ready to end, press the "Stop and Exit" button.
LabVIEW coding:
To run this tutorial, you will need:
Additional Resources:
Any questions, just ask!
Coding attached for LabVIEW 2011.
thank you, this was an excelent turorial!
ps could not see the video, it was marked as private u.u
I am glad that you liked the tutorial. We are just working to finalize the video and it will be available ASAP!
I can't see any tutorial, am I missing anything. Please let know how can I watch these tutorial, since it seems to be interseting topic
Hi rajinder101,
The written tutorial is contained within the PDF file "MyDCMotor.pdf".
If you're wanting the LabVIEW step-by-step instructions, then you can either use the Application.exe with the LabVIEW run-time or you can download the source files with the full LabVIEW environment.
Hope this answers your questions!
Hi Tori!
Thank you for your turorial
Are you able to save those *.vi 's for LabView 10?
Tanks!
