NATURAL AIR CONDITIONER
The Challenge
In today’s lifestyle major problem faced by people is to protect them
from environmental pollution and the major pollutant of
environment is the harmful gases emissions which are present
everywhere.
The Solution
The solution to such problem is by use of renewable source of
energy with use such methods we can save our environment from
the harmful gases and emission done for cooling and heating for this
a environmental friendly solution is natural air conditioner which
uses renewable source of energy for cooling as well as heating.
Depending on latitude, the temperature beneath the upper 6 meters
(20 ft) of Earth's surface maintains a nearly constant temperature
between 10 and 16 °C (50 and 60 °F) so we use this region for our
project
Introduction
As we know as per geothermal gradient temperature of earth
increases as we go deep in the earth if we cross one layer then the
temperature starts increasing but here we are not crossing the
layer so temperature below the crust (top layer) remains constant
so when we put pipe 20 feet under the ground as shown in figure,
as the pipe is metallic so when air goes from opening no 1 its
molecule hit wall of pipe No 2 it looses/gains its temp till it comes
to an equilibrium and this air is put in room by fan no 2 and air in
room is taken by fan no3 and this air is again pushed back to
underground point no 4 by pipe no1 and is mixed with air coming
from fan no 1 and again pulled back to room
WORKING AS AIRCONDITIONER
As in summer the temperature increases to 45 to 48 degree Celsius so
temperature of top layer of crust is increased equally so this
arrangement will work as air conditioner during summer time the hot
air is taken in by fan1 and through pipe no 2it is taken to ground and
ground temperature is about 10 to 16 degree Celsius as we know heat
moves from high temperature to low same as water flows from place
where water level is high to low so when this air is pushed back to room
by fan no2 , it feels cool and same time the air which is hot is taken by
fan no3 and air is reached to point no4 through pipe no 1 and is mixed
with air coming from fan no1 and it again pushed back to room by fan
no 2
WORKING AS HEATER
During winter season the temperature decreases to 5 to 8 degree
Celsius so temperature of top layer of crust is decreased equally so
this arrangement works as air heater in the winter season so the cold
air is taken in by fan1 and it is taken to ground by pipe no2 and
heat moves from high temperature to low same as water flows from
place where water level is high to low so when this air is given by fan
no2 in the room, it feels hot and same time the air which is cold is
taken by fan no3 and air is reached to point no4 through pipe no 1
and is mixed with air coming from fan no1 and it again put in room
by fan no 2
System Implementation
The system can be implemented anywhere as it requires one time
payment and very little on maintenance as compared to
conventional air conditioners as natural air conditioner requires less
electricity to run because here we are running both fans by solar
energy so it is very eco friendly and also cost effective measure for
air conditioning particular premises
Benefits
o Significant reduction in annual primary energy demand.
o Space cooling not dependent on refrigeration.
o Eco friendly.
o Large energy savings over both natural ventilation and air
conditioning and in air heating.
o Windows can be opened during the day, unlike with air
conditioning systems.
o No release of harmful gases
o The fundamental concept in the planning and design of
project was the harmonization of six environmental
components: ‘wind’, ‘light’, ‘heat’, ‘water’, ‘earth’
and
‘plants’.
Comparison of both air conditioner
Pollution by conventional air conditioner
- Release of harmful gases.
- Release of hot air.
- Use of plastic which cause further pollution.
- Use of electricity which is non renewable source of energy.
Benefits of natural air conditioner
- No release of harmful gases.
- No release of hot air as system is self sustained also.
- No use of plastic use of only metallic equipments.
- Uses solar energy to run fans so no electricity bills.
Conclusion
There are many advantages of using Natural air conditioner as it is
cost effective, Eco friendly, and has non dependency on electricity.
As there are many advantages of natural air conditioner so people
have to be made aware about its cost effectiveness and eco
friendliness so that this system is taken as a new generation eco
friendly solution to air conditioning needs of people who switch to
conventional air conditioning method. This new system will create a
new era in the field of environment friendly development!
TEMPERATURE SENSOR AND CONTROLLER
The Challenge
The main challenge is to control the temperature in a limited
environment i.e. Room temperature at defined specific temperature
with the use of the said method there will be no fluctuation of
temperature from user set temperature.
The Solution
In order to find solution to the said challenge for controlling
temperature various device like thermostat are being used
traditionally in all heating and cooling devices i.e. Thermostat of
heater user sets the temperature and if the temperature crosses the
set temperature the thermostat cuts off the supply to heating
element .In reverse conditions if the temperature of room still rises
due to some conditions then thermostat will not function still the
heating element doesn’t reaches up to the set temperature were the
situations is use of temperature sensor and controller in this air
conditioner and heater are connected to this circuit and user can set
the temperature using two switches it will help in controlling the set
temperature.
Introduction
The temperature sensor and controller is designed to sense the
temperature and control the temperature of the environment using
air conditioner and heater simultaneously with the help of designed
circuit there will be no fluctuation of temperature set by the user the
temperature will be controlled using two inbuilt switches one switch
to increase temperature with the help of heater and other switch to
decrease temperature with the help of air conditioner if the
temperature of room is above the required set temperature then it
will switch on air conditioner to reduce the temperature and if
temperature is below the required set temperature then it will
automatically switch on heater to increase temperature
System Working
The system works to control the set temperature set by user where
air conditioner and heater are being used for obtaining the set
required temperature in a room or specified area for example if user
sets the room temperature to 21°C and the room temperature is
10°C then it will put heater on and increase the temperature to 21°C
and switch to idle state and if due to some external source if
temperature increases to 21.1°C it will put air conditioner on and
bring temperature to 21°C
Detailed working of circuit
As soon as the circuit is switched on it will first sense the
temperature through temperature sensor i.e. LM35 now LM35 will
give analog signal in form of voltage to ADC0804. ADC0804 will
further convert analog signal to digital as microcontroller is capable
to deal only in digital signals as the voltage received by ADC0804 will
be multiplied by 10 and we will get corresponding temperature it will
be displayed on LCD and now it is compared with the temperature
set by the user if it is greater than the set temperature by the user
then it will switch on air conditioner and if it is low then it will switch
on heater
Benefits
It can be used in home appliances (ex. Air-conditioner, refrigerator etc)
It can be used in food technology
In automobiles
In medical/chemical industry
In fabrications
Modular discription of the job
Front View of Temperature sensor
Circuital View of Temperature Sensor
This is temperature sensor it can only sense the temperature of the environment
and display on the screen
Front View of Temperature Sensor and Controller
Circuital View of Temperature Sensor and Controller
Circuit diagram
Conclusion
The system is designed to sense and control the temperature in turn
helping to control any fluctuation in temperature. This new system
will help in creating better temperature controlled environment
across personal and industrial establishments where temperature
plays a vital role.
