SMART HOUSE APPLICATION
Via LabVIEW
University: Islamic university of Gaza – Gaza strip – Palestine
Team Member(s): AbedAllah A. Al-Tahrawi, Hossam R. El.Hennawi , khaled H. Dawoud , AbedAllah M. Abu-Zor & Belel A. Al.Saaty
Faculty Advisors: Dr. Basil Hamed
Email Address:engtahrawi@gmail.com
Title:
Description:
Smart House consists of three type of controlling systems, which enablethe user to control and monitor each system. It create database files which canstore each orders in smart house, and can be scheduler the start and end timesfor each system in house.
Products:
LabVIEW software version 2009
Data acquisition card ( NI USB-6008 )
Report_Generation_Toolkit_for_Microsoft_Office
Inferred Transmit and Receive
RF Module Transmit and Receive
Optical smoke detector
Heat detector
PIR Motion detector
Shock detector
Temperature sensor ( LM35 )
Sun cell
Magnetic switch
Limit switch
PIC16F877
PIC16F84
555 Timers
ULN2804 & ULN2003A
The Challenge:
Each of us needs comfort and safety in ourlife. Many real systems used in building don't have the flexibility and theability to give users all comfort and safety that they need. Making a completed system is a big challengebecause of the need to make many controlling system which can run in the sametime. Our project include many system which controlled by LabVIEW such as: firealarm system, burglary alarm system, internal light system, external lightsystem, remote control system, conditioning system, power supplies switchingsystem, and garage door system.
The Solution:
Smart House, give users a flexibility and efficiency to control allsystem. By LabVIEW software, users can put a special configuration on settingscreen in order to activate any system and to schedule the run time for thesesystems. LabVIEW has a monitor screen which can show any change in the housesystems. LabVIEW is connecting with remote control which gives us the abilityto put many modes for our controlling system. Besides that, LabVIEW give us theability to send SMS for especial change
LabVIEW software able to do …
LabVIEW, Monitor screen
LabVIEW Software, Setting Screen, Model No.1
LabVIEW Software, Setting Screen, Model No.2 |
Internal lightingSystem
The internal lighting systemconsists of a PIR motion sensor, dimmer and lamps which have a direct controlby LabVIEW software. This system will make an automatically lighting in thehouse when there is any movement inside it. Dimmer can use to make a small lamplighting percentage, and LabVIEW will make a 100% lighting for the lamps whenit receive a movement signal from Pmotionsensor and the user can scheduler the time of running the system .
External lightingSystem
lighting system depends on a sun cell reading that the DAQ read it and give it to LabVIEW software to analysts it. So LabVIEW software has an indicator about day and night time of in order to control the status of external light lamps.
Fire Alarm System &Burglar Alarm System
When an fire (or Burglary) happen in house , labVIEW will receive signal from fire (or burglary) sensors , and can be able to send SMS to two different mobiles and run the fire alarm siren as user need , in addition LabVIEW can sent signals to help put out the fire ( or to make more safety for the house ) |
Temperature System
The basic thing in temperaturesystem is the reading of temperature value from temperature sensor. For that,we use LM35 temperature sensor. This sensor is connected directly with DAQ.LabVIEW read the signal from LM35 sensor as variable analog value. Afterprocessing the structure in the program, LabVIEW will sent a cooling or heatingsignal to the system, depending on the value of the sensor and the criticalvalue of temperature that required. In the mechanism of temperature systemprogramming, we use PWM system to control the heating and cooling devices .
Central Unit and Rooms Units Remote Control
The remote control is used to make some operation in the system by connection it's with LabVIEW software. In addition, it used to control and switching the load in every room in the house using the rooms units receiver in every room, as well as used alone transmitter remote to control the Garage door. So the system has two transmitter remote control one used for internal controlling (Central unit and Rooms units) and another one used for external controlling (Garage door). |
Garage Door Remote Control
Wemade a special remote controlwhich can carried in the garage owner's car to enable him to open the garage door when the car be closed from thegarage
Automatic Water Level Control System
A three phase induction motor is installed todraw water from a reservoir and pump it into an overhead tank; the motor can bestarted and stopped with the help of limit switches operated by floats toprovide automatic water level control.
Central house power switching system
Its SubVI consist of send a codes number to microcontroller via DAQ, some of these to turn ON and other to turn OFF the power switching. |
Data storage
Web connection
Images
Control Panel |
<insert videolinks here>
Soon
Hey eng.3zam,
Thank you so much for your project submission into the NI LabVIEW Student Design Competition. It's great to see your enthusiasm for NI LabVIEW! Make sure you share your project URL (https://decibel.ni.com/content/docs/DOC-16229) with your peers so you can collect votes via "likes" for your project and win. Collecting the most "likes" gives you the opportunity to win cash prizes for your project submission. I'm curious to know, what's your favorite part about using LabVIEW and how did you hear about the competition?
Good Luck, Liz in Austin, TX.
hey liz
thank you for replying
i heared about the compettion by myself via your website
LabVIEW is very very interesting program, all of thing in this program is easy and i advice all friend to use it
Hi guys .. first of all I wanna tell you that you have a good project .. this application is very important in our life. I hope you to do the best in this competition, may Allah bless you all
Awesome work .. I hope u to be selected
Hello , would u please tell me about the cost of this project
good luck my friends
thanks for all
hi, Michaltrostrick
did you ask about the cost if you want to implement it in real home
or the cost of this study as university project ??
Hi my dear friend , your project is amazing and helpfull for our dealy life. i hope you win in this competition
it's a great job my brother hossam ...I didn't read it yet and I don't have no idea about the new technology which you use ....but I will do inshallah when I have time , i promise !!
hope you the best hossam !!
abdelaziz- your brother from Morocco
thank you very very much my friend abdelaziz for supporting us in this competition ... I hope you will have time to read the details about the project and about the technology which we used .....
thank you again my friend ... don't forget praying for us ..
Nice projects man>>>
good luck guys
oooh nice work
congratulation
Tthank you very much Dr.Basil .... we hope so. pray for us to win in this competition
Nice work... Good luk
بالتوفيق ان شاء الله
my frinds .. actually it's great project .. and i wish for you to win at these competition and at incoming competition wherever domestic or international .. i wish you bright futuer from my heart ..
your brother
Ammar Mattar
عشان خاطر تعبكم في ايملكم الطووييل ،، احلا كومنت لقادة المستقبل وان شاء الله منها للأعلى ياذن الله
بالتوفيق
بالتوفيق
الف مبارك وبالتوفيق في المسابقة
project unique and wonderful
مشروع رائع وبارك الله فيك
أسأل الله لك دوام العافية في الدنيا والاخرة
ohhh that nice project
good job, and i hope your project win.
good luck
Great Project,
All the best ,
Nice work
Good luck
الف مبارك شباب وان شاء الله موفقين وترفعوا راسنا
بجهدكم وعملكم وسهركم ستفوزون بإذن الله
مشروع رائع ويعطيكوا العافية يا أبطال
وتحية خاصة للأخ عبد الله الطهراوي من أخيك أبومالك
Dear Brother,
Allah bless you, continu to success in your live to enhance our country
Take care
I think it may be great project
may god help you
best regards
I wish you all the luck
very nice>>>>>
Very Nice Project
Good Luck
muy bueno el proyecto ...
you must win
i hope it from all my heart becuse you are make awnderful things to OMT MOHAMD
الله يوفقكم
I wish you luck and success in your career, scientific and personal
great
