Sensor Type: Pressure (Temperature)
Manufacture/Model Number: SparkFun: BMP085
Link to Sensor: https://www.sparkfun.com/products/9603
LabVIEW or C: LabVIEW
Version of LV: 2013
Description/Instructions on how to use this example:
This example reads data from BMP085 Pressure\Temperature Sensor, processes the data and displays the data on the waveform chart.
Instructions:
1. Connect sensor to NI myRIO
2. Open .lvproj in attached .zip
3. Open and run Main.vi
Wiring Diagram of Sensor to myRIO:
BMP085 Pressure\Temperature Sensor myRIO
VCC +3.3V
Gnd Gnd
SDA Connector A/SDA
SCL Connector A/SCL
Code: myRIO SparkFun BMP085 Pressure (Temperature) Sensor.zip attached
