University:NANJING UNIVERSITY OF SCIENCE AND TECHNOLOGY
Team Member(s):WangLei , HeShan
Faculty Advisors:ZhangZhongxiong
Email Address:119958838@qq.com
Title: The solar panel automatic tracking system based on LabVIEW
Description:
The project introduces one kind of automatic tracking system of sun which effectively combined the sun angle tracking and photoelectric tracking. The tracking system can track the sun real time all weather in the day, and raised the utilization efficiency of solar energy.
Products:
NI hardware:
PCI-6251 DAQ Card
68 pins high-performance shielded cable SHC68-68-EPM
68 pins shielded and high-performance binding post SCB-68.
NI software:
LabVIEW 8.2
The Challenge:
1 Uses LabVIEW to realized all-round tracking of the sun from the horizontal and vertical direction which can overcome the shortcomings of traditional low solar utilization.
2 Tracking fully automated. This project can judge the weather is cloudy or sunny to pick the tracking mode automatically. If it’s cloudy, the main tracking mode is photoelectric tracking, or the main tracking mode is the sun angle tracking .
3 This project has manual adjustment system and automatic return system at night .When the project due to external factors produces mistake, you can use the manual adjustment system to recover the project in a short time .
4 This project also has the motor protection modules. It can prevent motor damage when the Motor shift to the limit.
The Solution:
<how does your project work>
First of all, when we press down the start button, the whole system begin to initialize which can make the solar panel almost over against the sun. The next is waiting for twenty minutes ,then the system execute the sun angle tracking so the solar panel can track the current sun position from the initial position .finally, the solar panel can over against the sun accurately through the photoelectric tracking .
<explain the benefits using LabVIEW and NI tools>
1 Using LabVIEW we can conveniently build our own virtual instrument in that the LabVIEW is a Powerful and flexible software.
2 LabVIEW describe the programing behavior through the graphic symbol ,so it can eliminate disturbing grammar rules ,reduce the programmable burden and improve efficiency.
3 The price of the software is low. Because the LabVIEW based on software architecture,it greatly reduces the development and maintenance costs.
4 Due to the key of the virtual instrument lies in software, hardware limitations is smaller which is easier to connect with other instrument set .
5 we use the NI company product PCI-6251 In our project. This product can seamlessly combine with the measuring driver service software such as LABVIEW and NI-DAQmx and offer higher performance, higher value and the more I / 0.
As above mentioned, we simplify the project development process, make debugging simple and shortened instrument development cycle by using LabVIEW and NI tools.
<insert image(s) of project with captions>
figure1 PCI-6251 multi-function DAQ card
figure 2 68 pins shielded and high-performance binding post SCB-68
figure 3 PCI-6251 and SCB-68 connection diagram
figure 4 Four quadrant photoelectric sensor
Annotations:It is used for photoelectric tracking.We do it by ourselves.
figure 5 drive circuit
figure 6 The Front panel
figure 7 The solar panel
<insert video links here>
Hi 421,
Thank you so much for your project submission into the NI LabVIEW Student Design Competition. It's great to see your enthusiasm for NI LabVIEW! Make sure you share your project URL(https://decibel.ni.com/content/docs/DOC-16490) with your peers and faculty so you can collect votes for your project and win. Collecting the most "likes" gives you the opportunity to win cash prizes for your project submission. If you or your friends have any questions about how to go about "voting" for your project, tell them to read this brief document (https://decibel.ni.com/content/docs/DOC-16409).
I'm curious to know, what's your favorite part about using LabVIEW and how did you hear about the competition? Nice work with the NI myDAQ!
Good Luck, Jessica in Austin, TX.
This product is so nice! It is a high-tech!
well done!
well done!!
well done
very good!
He Shan Come on ! Good
you‘re doing a fine job!
very good! fighting!!!!!
the project is so creative!
I can say only good !!!!
This is very good, very creative, can provide us a good help
for the development
good job!!
投个票真不容易啊,不错不错
very good!!
