You can play thermin by using this VI files.
It needs an IR range finder, sonar range finder, and speaker.
The IR range finder is used as varifing pitch. The sonar range finder is used as volume sensor.
You are able to use practice mode. This mode has approximating twelve tone function and tuner function.
