Student Projects
Visualization of ship motion simulation platform
ContactInformation
University: GuangDong University of technology
Team Member(s): Haoming Lu,shubin Chen, Weipeng Lin, Ziyuan Yang, Weiwen Zeng.
Faculty Advisors:
EmailAddress:xw_studio@126.com
ProjectInformation
Title:Visualization of ship motion simulation platform
Backgound
When I as a child, I have a dream, that is, oneday, sailing out to the sea, and want to know what is in the other side of the sea. When I grow up, I selected to learn automation, but the dream is always in my heart. I realized that it is unlikely driving a ship to the sea in reality, so, based on the instrument LabVIEW, we designed a ship movement simulation platform for practice the feeling.
Another, The simulation system can be used not only teaching and training, but also can be used for scientific research and engineering design assistance, popularization and the popularization of knowledge also has extremely important.
Moreover, as we all know,the development of human civilization has something to do with ocean transportation. All kinds of activities in the sea ,not only geological study but also oil mining.In a way we can say that who has the Initiative of the sea , wo will Master its destiny.However,there are all kinds of dangers when a ship navigate the sea.How to control the ship navigate the sea safely is a big and difficule problem.So the ship control draw a lot of experts' attention.
Because of these,our team use the Labview Software exploit a program,help the people who want to design a ship control system safely and economically.we build up a ship model in our computer,and wo also create a sea scene in it.The most importent is that wo provide a interface for the user in the progrem,the user can input  their date of ship control,and then you will see your ship navigate the sea according to your input.
Help
Please open the project called ‘Visualization of ship motion simulation platform.lvproj’未命d名.jpg , double click the Main.vi未的命名.jpg,
enter the customer welcome interface, and then click the Run botton 1.jpg to the upper left corner, click on "Enter System "key的.jpg to enter the ship parameters setting page(the default parameters on this page comes from the real ship ‘Mariner’ ),of course, user can also modify the parameter by yourselves, the system will calculate and get the ship motion mathematical model automatically.Click the ‘Next’ key and enter the simulation interface.
The simulation interface is made of 6 sub-interfaces including environment parameters setting,position and mode,navigation direction and speed control,navigation path,output curves of control forces. Clear interface,easy to operate. At first, on the upper left corner user can type the relevant values ​​arbitrarily to set the environmental parameters of the current sea including the dirction and scale of wind,wave,current. Then toggle the stick called ‘hand/auto’未命的的名.jpg to choose the control mode of the ship.
auto mode:please type the abscissa x1, longitudinal coordinates y1, heading angle α to ensure the starting location of the ship, type the abscissa x2, longitudinal coordinates y2, heading angle β to ensure the ending location of the ship. And then togglling the stick ‘start/stop’未命全球名.jpgto start simulation, observe the simulation of the ship.
hand mode: turn the steering wheel to control the direction of the ship's,enter the value of the pushing device to control the ship’s forward and backward.enter the value of the thruster to control the ship’s movement of left and right.
User also can adjust the ‘visual angle ajustment’ to achieve multi-angle all-round observation.
Navigation process, navigation locus shows the current location coordinates and navigation track clearly. Also, user can also observe the control forces changes by the output curves of control forces.
reset:For resetting the initial position of ship ,enter the values and click the reset 方法.jpg to
Program Description
According to the main idea of the control system, in the main program we package the control module, interference module and control plant and so on into subVI, which make the framework clear and make it possible to transfer data at each subVI. In addition ,it is intuitive for people and it remove the global variable trouble .The program diagram is fit for the data stream of the LabView idea and the inner structure of each subVI is simple so that we can save lots of memory space which will snow down the operation efficiency .At the same time ,appropriate local variables can reduce the complexity of the wiring and make it easier for readers reading .To avoid the competitive problem ,it is necessary for us to try to avoid using multithreading control.­­­
The switching between user interface and parameters setting interface is use independent calls which make it possible to fully close the user interface without any data connection when we switch the user interface to parameters set interface so that we can reduce the using of memory .
The switching between parameters setting interface and control interface is use inner nested for prevent the data loss .All interfaces through simple judgment structure or conditions structure realize interaction.
The calls of the 3D model are use judgment structure to realize .When the first call come , the 3D model file will be opened and after that , we separate the 3D model into two parts to control .With the help of the det shift register ,we can achieve the data update and the synchronization between data and 3D model.
We use the camera module, which we can find in 3D toolkit of the LabView , to achieve the boat tracking and visual adjustment for readers having a better observation in the simulation conditions .Adjusting the coordinate , we can get different angles and we can magnify or narrow the 3D module space to observe the simulation conditions. So it not only satisfy the readers’ visual requirements but also have a stable dynamic model display without any distortion in order to have a better results.
Thank you for your view !!!
Comments
zhangmiaomiao
Member
Member
on
excellent...
zimine
Member
Member
on
good
Eric_zheng
Member
Member
on
good job!
a nice simulation platform!
mc-kate
Member
Member
on
You did a good job!  Your product is amazing!
Ttang
Member
Member
on
it is good !!!!
pug
Member
Member
on
good Job
Ttang
Member
Member
on
it is  good  !!!
wen110
Member
Member
on
无敌了,,,
pug
Member
Member
on
good
gfdgfdh
Member
Member
on
good jod
KIKO_Chenyx
Member
Member
on
I hope your  dream  will  come true someday!
gonghai
Member
Member
on
WELL DONE!
sheyezhong
Member
Member
on
太棒了!!!!!!!!!!!!我爱你!!!!
vikenpoon
Member
Member
on
That‘s so great~
flyfly
Member
Member
on
nice~
iviv
Member
Member
on
Good job!继续努力!
Royzlw
Member
Member
on
that is the best i have seen.well,good luck!
viking123
Member
Member
on
wooooooo!!!!!  that's incredible!!!!
abccba
Member
Member
on
very nice!
outdate
Member
Member
on
it seems wonderful,but i can't catch what it means.
洽生
Member
Member
on
very good,well done!
chenxuanqiang
Member
Member
on
不错,加油~
rogerfeng10
Member
Member
on
great! 伟鹏加油啦!
o_oxmay
Member
Member
on
good boy!
lrdandmay
Member
Member
on
great....
lrdandmay
Member
Member
on
加油,.....
770597808
Member
Member
on
good
舫流
Member
Member
on
well done!!
舫流
Member
Member
on
继续努力
了了
Member
Member
on
nice!
空气补给站
Member
Member
on
Nice...well done!!
snoopy99
Member
Member
on
well done!!
空气补给站
Member
Member
on
well done
ojh
Member
Member
on
很不错
ojh
Member
Member
on
很好很不错
jie2012
Member
Member
on
good
hahakong
Member
Member
on
good job!
何家小鸡
Member
Member
on
Great!!!!
何家小鸡
Member
Member
on
Very good
siyfirst
Member
Member
on
amazing!!
marbledcat
Member
Member
on
乌鲁塞
sureling_mai
Member
Member
on
Good!
juanluan
Member
Member
on
very good~
juanluan
Member
Member
on
继续努力
charby
Member
Member
on
That's great!
charby
Member
Member
on
That's great!
zrrat
Member
Member
on
Very good!
cjw1281
Member
Member
on
good
qq99pp00
Member
Member
on
very good soft~~
DavidEriol
Member
Member
on
Professional and applied!!
Contributors
