Student Projects
Why go to the casino when you can create your own blackjack dealer using LabVIEW.
Rules:
The object of the game is to reach a card value as close to 21 as possible
without going over.  Each round your score will be compared with the
dealer's, determining if you win or lose the round.  Each card is given a
value that is equal to it's number, face cards recieving a value of ten.
Getting a value of 21 with your first two cards is considered a "Blackjack"
which beats any other combination, or ties with a "Blackjack drawn by the
dealer.  The minimum bet each round is ten dollars with the maximum bet
being 100 dollars.  Winning the round rewards the player with the amount
he or she bet, while losing the round costs the player that same amount.
If the player should win by drawing a "Blackjack", the dealer pays out
double the amount that they would normally.
Gameplay:
The player starts out the game by entering their name, or choosing to load
a previous game from the "Game Saves" folder.  The players game is
automatically save after each round in the "Game Saves" folder under the
name that was given at the start of the game.
Each round starts out with the player making their bet and then pressing
the "Deal Button", after which no further bets may be made.  The dealer
displays one card down and one card up.  Then the player clicks on the
downfaced card, turning it over and revealing the initial draw.  From there
the player may "Hit" or "Stand", depending on their current card value.
A "Hit" will draw one card and a "Stand" will end the players turn, keeping
the cards which they currently have, and then give the dealer the opportunity
to "Hit" or "Stand".  The player may take up to five cards total.  The dealer
must "Hit" with a total card value being 16 or less, and must "Stand"
when having a total card value 17 or greater.  If the player "Busts",
goes over 21, the round is automatically over and the player loses.
Aces can count for values of one or eleven, depending on the players hand.
If the player goes over 21, Aces will automatically reduce in value from
eleven to one.
Instructions
1. Download the attached zip file
2. Double-click extract all files (see image on Connect 4 Document for visual)
3. Double-click the "blackjack.exe" file to launch the game (see image on Connect 4 Document for visual)
4. Hit the run arrow below the toolbar to start the game
Contributors
