This Multisim file should serve as the starting point for the schematic capture of a circuit for future layout in Ultiboard and myDAQ integration. The file is the myDAQ template with the PCB combicon connected to it with a Bus-vector connected and configured.
The AI0- and AI1- are both connected to ground, you can delete the wires in the bottom that connect the AGND to the AI0- and AI1- lines on the bus vector, or you can download the project with RSE appended to its name.
