Switch Hardware and Software
What function besides setting the topology do you use to control the BC01, BC02, BC23 relays? You are able to do it from the relay tab of the front panel.
(6,218 Views)
whl6868,
You Can Use the DAQmx or NI-SWITCH Relay Control API to select a Relay and command an action. Normally those relays are used to set topologies.
Frank,
Software Group Manager
(6,213 Views)
Thanks. Will try that, just that they were not listed as valid relays for the niSwitch_RelayControl in the documentation.
(6,196 Views)
