Switch Hardware and Software
3 amps carry current
Hi... I am looking for a 3U PXI based Form A relay module with the following specs:
Switching Power : 50 Watts max
Switching Current : 2.0 A max
Carry Current : 3.0 A max
Breakdown Voltage : 500V rms
Path resistance : <= 2 ohms
Thermal Offset < 75 micro amps
I would like to squeeze in as many Relays as possible in one card as I require 400 such relays.
Pls let me know if there is any hardware that matches this requirement....
(6,680 Views)
Spec Requested
PXI-2564
Switching Power : 750 VA [AC], 150W @ 30 VDC, 30W @ 150 VDC
Switching Current : 5A max
Carry Current : 5A max
Breakdown Voltage : 1000 Vrms (according to relay datasheet)
Path resistance : <100 mOhm initial, >= 250 mOhm end of life
Thermal Offset : not specified, even in relay data sheet
PXI-2566
Switching Power : 60 W, 62.5 VA
Switching Current : 2A max
Path resistance : <100 mOhm initial, > 1 Ohm EOL
Thermal EMF : <9 uV @ 23 degC
Hopefully, once of these will work for you!
RossC
(6,674 Views)
