Switch Hardware and Software
3499 with 44470A and 44471A
Husni,
I think that I miscommunicated how I wanted you to create a log file. You probably logged all operations and then saved the log to a file. What I'd like you to do is go to options, and select logging to a file. This is the only way I can view all the internal calls that transpire - you won't be able to see the difference yourself, other than the log file size being significantly bigger than the one you posted.
best regards,
-Serge
ps. I understand that everything is working for you now, can you confirm?
Message 11 of 12
(3,862 Views)
Srdan,
Sorry about the log file misunderstanding. Anyhow attached is the log to file capture file.
And yes, everything is working now.
husni h
Message 12 of 12
(3,835 Views)
