Switch Hardware and Software
Any PXI video switch hardware?
I am developing a system that must be capable of simulating, in part, a simple video switch.  There are three separate video sources as inputs and six possible video outputs, two for each input.  In essence, I need an SPDTx3 switch module for a PXI chassis that can handle RS-170A video signals.  The only solutions I have been able to find so far are video multiplexers, which would work, except I'd have to buy three of them and use half of their capability at most.  Not very efficient or cost saving.  Has anyone come across a solution that will integrate well with National Instruments products?
Dan
(7,332 Views)
Dan,
I wrote a great application note published on our website about using the PXI-2593 for video switching in a 75 Ohm system. This switch should be perfect for your application.
Guy Ferraro
Switch Product Support Engineer
NI - USA
(7,330 Views)
It does look perfect.  I had previously read your whitepaper, but your example PXI card didn't click in my brain as a possibility.
Thanks.
(7,328 Views)
I am glad we could help. Good luck.
(7,324 Views)
