Switch Hardware and Software
Cable/Connector Recommendation for connecting to PXI-2527/TB-2627
I have a high voltage DMM to 64X1 MUX  application where I would like  to route a ~1 meter cable from from the TB-2627 terminal block to a PCB connector.   I can't find a cable and PCB connector that matches the voltage/current capabilities of the PXI-2527(250V/2A).   Does anyone have a suggestion/recommendation?
BTW:  I'd like to eliminate the bulk of using a TB-2627, but directly connecting to the AMP HDI100 connector on the PXI-2527 via cable connector is not a solution either because this connector is PCB connector-to-connector mating only.
(7,075 Views)
Hi Actechy,
National Instruments does not offer a cable assembly.  You can either use the screw terminal block or create your own cable assembly.
If you go to the 2527 product page, click on the Specifications Tab >> Detailed Specifications >> NI-PXI-2527 Specifications >> View.
On page 4, we list some connectors from AMP, which is sold by Tyco Electronics, that can be used with the switch.
Here is another thread that addresses your issue:
PXI-2527
Thank You,
Nick F.
(7,066 Views)
