Switch Hardware and Software
DAQmxSwitchGetMultiRelayPos
I have a PXI-2566 relay module, and I am trying to query the position of every relay in the module.  I see that there is a function DAQmxSwitchGetMultiRelayPos, but the documentation for this function is extremely poor.  My question is, how am I to format the relayList string that gets passed to the GetMultiRelayPos command?  Do I just put the values (0-15) in this list, or (k0-k15), or /PXI1Slot2/k0 - /PXI1Slot2/k15, and are there separators between the values?  More extensive documentation aside from "the set of relays you want to query" would be helpful.  Thank you for your time.
(6,718 Views)
Sorry for the unclear documentation.
What environment do you use? If you are in CVI, you can bring up a function panel for the DAQmxSwitchGetMultiRelayPos function, and click on the "..." button next to the relay names control, then click on 'browse' and multi-select relays.
If you then examine the generated function call, you will notice that the syntax for the range of relays is using colon, e.g.
"/PXI1Slot2/b0r0c5:12", or in your case, "
/PXI1Slot2/k0:15"
I hope this helps!
(6,715 Views)
