Switch Hardware and Software
Error -1074126826 occurred at niSwitch Initialize.vi
I'm getting an intermittant error with my switch card:
Possible reason(s):
Max time exceeded.
Device: SWT1-DUTSwitching
Status Code: -200221
It happens about 25% of the start-ups (fixed with a restart).  I can't find the error codes in any documentation - has anyone got any ideas please?
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(7,192 Views)
Hi crelf,
May I ask what version of the NI-Switch driver you are using?  If you are not using NI-Switch 3.3.1, the solution to your problem will be to upgrade to this version (or the latest available).
Recently, we found that a hard reboot could cause intermittent switch module operation similar to your description.  It didn't always occur on the same switches every time, and a soft reboot would often fix the issue.  This issue was noted to occur with DAQmx 8.1 / NI-Switch 3.1 and DAQmx 8.3 / NI-Switch 3.3 driver versions.  We incorporated the fix with NI-Switch 3.3.1.
Please let me know if you have further questions or if this does not resolve your issue!
Chad Erickson
Switch Product Support Engineer
NI - USA
(7,188 Views)
G'Day Chad - thanks for your answer: after several weeks of testing I haven't had the error message since I upgraded to 3.3.1!  Well done 🙂
(7,148 Views)
