Switch Hardware and Software
Example Switch Executive VI hangs
Hi
I'm trying to create a list of connected relays using Switch Executive VIs and been looking at some of the examples. In one of the two libraries, is a VI called 'Getting Started' so I had a go at running that to see how it worked, using the default virtual device name & connection specification. However, I've found the VI just seems to hang and when I try to close it, a message pops up about Resetting the VI, which doesn't disappear & I can't close. I have to quit Labview from the task manager to get round it.
Trying this again, with execution highlighted on the block diagram & a probe on the 'session out' from the Open VI that's called up, it shows the session value is zero but the error path reports OK.
If I change the virtual device to one I created in Switch Exec & update the connection spec, the session value is now non-zero but I get error -29003 when executing the Connect VI, which states "This session is not a valid NI Switch Executive virtual device session" so I'm not sure where I'm going wrong. That said, I'm able to use my virtual device name in a TestStand IVI switch step without a problem.
Since I'm using a mixture of software versions (Labview 2017, Switch Exec 2015 & TestStand 2014), I wondered if it's a compatability issue that's causing this?
Appreciate any advice.
Bruce
(4,051 Views)
Hi Bruce,
This error can happen for a couple reason. But it does seem like it is an incompatibility issue for your case. Looking at the Switch Executive 2015 readme, it is only compatible for LabVIEW 2012-2015.
I have also seen this error when you are trying to use a version of Switch Executive with an incompatible Windows version. Such as using Switch Executive 2015 on a Windows 10 computer. Switch Executive 2017 was the first version to start supporting Windows 10.
(4,004 Views)
Hi Sherlockholm
Thanks for your reply. I'd forgotten to mention I'd just started using a Windows 10 PC. I've now upgraded my Switch Executive to 2019 (will be doing the same with TestStand), and problem solved.
Thanks & regards
Bruce
(3,925 Views)
