Switch Hardware and Software
Genereal Switch Questions
What is the difference between the Matrix, Multiplexer and General Porpuse modules?
Why are some SCXI and some PXI is there and advantage to one over the other?
Why do I see some modules under multiple types here: volt.ni.com/niwc/products/switch_topologies.jsp ?
Whats the difference between 145 Cycles/s, 25,000 Channels/s, 2000 Crosspoints/s, 10 ms, which are all listed under switch speed on the same page?
Thanks for the help,
Brian
(7,081 Views)
We have quite a few documents that answer your questions:
Some modules can be configured as multiplexer or matrix by using a very flexible design and placing judiciously relays on the PCB.
The difference comes from the type of switch modules you are referring to. Cycles/s, Channels/s, Crosspoints/s are for genral purpose, multiplexer, and matrix respectivelly that can be used in scanning mode.
ms indicates speed on switch mdodules that do ot suipport scanning.
I encourage you to look over this document: Complete Switching Tutorial
Guy Ferraro
Switch Product Suppport Engineer
NI USA
(7,078 Views)
Great! Thank you.
Message Edited by BrianPack on 07-22-2005 03:56 PM
(7,069 Views)
