Switch Hardware and Software
Having trouble using SCXI-1163R with DaqMx - looking for an example.
We currently use the 1163R as a traditional device just fine but when I try to use it as a DaqMx device I can't get it to switch any of the lines by accepting a 32 1d array of boolean. Any ideas or examples?
thanks!
Mike
(7,394 Views)
Hi Mike,
Are you attempting to do scanning with the SCXI-1163R? Are you using an example? Please elaborate more on this issue and I'll respond with information that is more helpful.
Chad AE
(7,381 Views)
Hi Mike,
If you are trying to send a bit pattern to the 1163R with DAQmx, you can use the VI called Write Dig Port. This example demonstrates how to write values to a digital output port in DAQmx.
In LabVIEW, if you go to Help->Find Examples...
Browse to Hardware Input and Output->DAQmx->Digital Generation->Write Dig Port.vi.
Let me know if this is what you were looking for!
Chad AE
(7,367 Views)
That will do it! Thanks!
(7,364 Views)
