Switch Hardware and Software
How do a reattach a tab to another tab.
I have a vi that has been running for quite some time. It has 5 tabs, with 6 more sub-tabs underneath each tab. One of the sub-tabs has become disassociated with its main tab. If I try to go to the other tabs this main sub-tab stays on top blocking the rest of the vi. I don't know what I did to cause this and need to fix it as soon as possible. None of the tabs are used or established progammaticly, so none of this advice will work.
(7,466 Views)
Yo might want to post on the LabVIEW forum: http://forums.ni.com/ni/board?board.id=170
Message Edited by Guy Ferraro on 02-16-2006 11:14 AM
(7,466 Views)
I have spent 2 hours going thru all of the messages in this forum, nothing helped. I have no way of fixing this problem, since I have no way of figuring out what I did in the first place!
(7,457 Views)
Hi Maciv,
This looks like a LabVIEW question and, as Guy mentioned, you may want to consider posting your question to the LabVIEW discussion forum (you are likely to get an answer to a LabVIEW question much faster on the LabVIEW discussion forum than on the Switches discussion forum). If you do repost, please include a copy of your VI so that others can take a look to see where the problem is and how to help. Best of luck!
Chris J
(7,432 Views)
