Switch Hardware and Software
Importing virtual devices from/to target computer and development computer.
Hi.  I'm having difficulty transferring a virtual device from my target computer to my development computer. (target computer has hardware devices connected and development computer does not...development computer is used to create routes, hardwires, etc...)
The problem is I've created a virtual device, lets call it device_template, on my target computer and I want to use this one as a template on my development computer but when I import my virtual device it is unable to locate some of my devices.  For instance, on my development computer I have one virtual device, lets say device1, is able to simulate without errors on my development computer but, when I create a new virtual device using device_template,  the other virtual device starts giving me errors.  This is the following error:
Testing IVI Configuration ... Error:
     An error has occured while attempting to access device scan2B_ivi
Error -223116 occurred:
Internal Software Error occurred in Switches software. Please contact National Instruments Support.
Component Name: niswdu
File Name: .\source\mxsWrappers\tMXSObject.cpp
Line Number: 192
Status Code: -223116
 Testing Routes ...
  Testing DMMToScannerOutput_ch0 ... Error:
Line Number: 192
Please help.
(6,707 Views)
Guy04,
Could you please tell me about your hardware/software (versions) you are using?
Ayman K
(6,695 Views)
I am using Switch Executive v2.0.
Also, do you have to have a seperate driver session for each virtual device configuration?
Message Edited by Guy04 on 09-26-2005 10:59 AM
(6,685 Views)
