Switch Hardware and Software
In Switch Executive, can you have one pins use one route?
Is it possible in Switch Executive to have one pin always use a specific row(route) and a second pin use a different row (route)?
(6,897 Views)
Yes, you need to predefine your routes.
(6,894 Views)
Thank you for your help.
The problem with doing that is when I close out of MAX and reopen it the routes would automatically use a default "reserved for routing" channel.
Solution:  When I converted to a licensed version this problem is solved.
Thanks again.
(6,890 Views)
