Switch Hardware and Software
Is there any DDK, RLP or examples programming Relay cards PXI-2567?
I am trying to write a Device Driver for PXI-2568 Relay card. I can not find any Device Driver Kit (DDK) or Register level Programming (RLP) information. I program in Visual studio C++ using RTX. I have diver for M and E series ADC cards as well as DIO cards, but can not find any help for the relay cards. Where can I find any examples or other info?
Tony
(6,768 Views)
Hi Tony,
I have RLP information on the PXI-2568, but the information is limited and may not give you all the desired functionality that you're looking for.  If possible, can you provide me an email address to contact you personally?  Because the information is somewhat limited, additional support may be required, so I would rather not make the RLP manual public.  Also, I would like to discuss the caveats to the existing RLP manual and verify the information I have will make you successful.  Please note the email address you provide will be public information (at least initially), so you may not want to use your primary email address.
Another option is requesting support through phone or email via http://www.ni.com/support/, however phone and email requests require a valid service contract.
Thanks in advance!
Chad Erickson
Switch Product Support Engineer
NI - USA
(6,760 Views)
