Switch Hardware and Software
Looking for connector to mate with SH68-68 cable
Greetings:
I am using a NI PXI-2531 in a test system.  I will be connecting to the PXI-2531/TB-2648 with the SH68-68 cables.  I would like to replace the TBX-68 with a custom CCA.  I an looking for the proper mating connector to interface with the SH68-68.  Are the 68-Pin Vertical or Right Angle PWB Mounting Connector (P/N 777600-01 & 777601-01) the right animal for the job or do I need to keep looking?
As a distant second and third choice I could make use of a panel-mounted crimp-n-poke or solder-cup connector.
Dave
(7,102 Views)
Hello Dave,
Those connectors will match up with the SH68-68, an as long as they will provide the correct connection for the other side of the connection then this should work for your application.
Thank you,
Justin
Justin
Product Support Engineer - Conditioned Measurements
(7,094 Views)
SH68-68-EP cable most commonly used Series Series cable. cable designed work specifically with Multifunction devices preserve signal integrity through these technologies:
Seperate digital analog sections
Twisted pairs critical digital
Individually-shielded twisted pairs analog inputs
Large AWG) conductor Lines
Figure offers wide variety
Double ground shield Individually-shielded analog outputs jacket
cable accessory options, such SH68-68-EP cable BNC-2110 terminal block.
variety cabling accessory options available your needs. following tables choose most appropriate cables accessories. determine which Multifunction device best fits your needs, please page 189.
Data Acquisition Signal Conditioning
Platform PCI/PXI/USB/FireWire
Shielding Shielded Shielded Shielded Shielded Shielded Shielded Unshielded Unshielded
Connect portable signal conditioning channel SCXI high-performance signal conditioning Screw terminals terminal block 50-pin connector Configurable connectivity Screw terminals 50-pin connector Front-mounted screw terminals Screw terminals 50-pin connector Screw terminals 50-pin connector
Cable SH68-68-EP SCXI-1349 SH68-68-EP SH68-68R1-EP SH68-68-EP SH6850 SH68-68-EP R6868 R6850 SHC68-68-EP SHC68U-68-EP SHC68-68-EP SHC68U-68-EP RC68-68 RC68-68
Adapter 68M-50F
Accessory SC-2345 modules, page SCXI Chassis Modules, page SCB-68 BNC-2110, BNC-2120, BNC-2090 CB50, custom party CA-1000, page TBX-68, CB-68LP, CB-68LPR, signal accessory CB50, custom party TB-2705 SCB-68, CA-1000 CB50, custom party TBX-68, CB-68LP, CB-68LPR, signal accessory CB50, custom party
only Shielded PCMCIA Shielded Shielded Unshielded Unshielded
(6,876 Views)
