Switch Hardware and Software
Minimum required software versions for USB-1359
Could anyone point me to documentation which lists the required software versions of DAQ-MX and any other oft needed to drive a USB-1359.
I know that on one system the USB-1359.run with NI-PAL 1.11.1f0 , but an another system  wirh PAL-1.11.1f0 installed windows finds no usable driver , the the device is plugged into the USB plug.
(7,515 Views)
markus:
For that version of PAL and USB-1359, you need NI-DAQmx 8.3 or later.
Brian
(7,514 Views)
Thanks Brian,
Do you also happen to know , what's the first version of DAQ-MX / NI  switch/ NI Switch executive  with proper support for the USB-1359.
Three years ago we did setup a SCXI-1001 with a PCI-4021 and now we have to duplicate that setup, but the 4021 is discontinued. So  we decided to switch to a USB-1359. And we want to minimize the changes in the software for the new setup.
(7,510 Views)
markus:
The USB-1359 driver first appeared in NI-DAQmx 7.4.  The DAQ readme does not reflect this.  It is, however, mentioned in the NI-SWITCH 2.4 readme.
Brian
(7,509 Views)
Hi Markus,
Every available version of NI-Switch and their README files can be found on Drivers and Updates.  The README files on these driver download pages show which devices are supported in that version, as well as the newly supported devices for that version.
Drivers and Updates >> Switches >> Software
http://joule.ni.com/nidu/cds/fn/p/sn/n23:12.75/lang/en
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
(7,409 Views)
