Switch Hardware and Software
NI SWITCH and Keysight 34980A with 34945A connected to a 34945EXT Remote Module
i am using a Keysight 34980A mainframe where i have
slot1=34932A
slot2=34937A
In MAX the Driver Setup in DriverSessions is: dmm=true, slot1=34932A, slot2 =34937A
When using this to create a Virtual Device then it works perfect and i get all channel names.
Now i want to add an additional card in slot 3
slot3=34945A which is connected to a 34945EXT Remote Module
What do i have to write now at the Driver Setup string?
A test with: dmm=true, slot1=34945A does not create any channel names in a new virtual device.
(2,567 Views)
Accepted by topic author OnlyOne
The question is resolved.
Unfortunately, the module is not supported.
Unless someone has a secret tip.
(2,561 Views)
