Switch Hardware and Software
PXI-2003 can i use it as MUX and DEMUX ?
Salve
I Can use  Multiplexer PXI-2503 part as MUX and part as demux ?
and how can i expand one mux 48x1 with another mux, for 96x1 ? How i have to connect signals of boards, and how i have to drive the PXI-2503 for this ?
Marcello
(6,761 Views)
The 2503 can be used as a DEMUX, when the topology that is used is a matrix. This kind of topology can also be used to create a Multiplexer (even if it is not a very efficient way to use it as far as resources go).
You can expand your Mux topology to become a 96x1 1-wire using 2 2503 modules, 2 2605 Terminal Blocks and an analog bus extender.
As far as examples go, it actually depends on the Application Dev Environment you are using, but once NI-SWITCH Driver
 is installed, you will find a whole set of examples just by selecting
Start>>Programs>>National Instruments>>NI-SWITCH>>Examples
Also you should be looking at the NI-SWITCH Online Help (.chm file) which documents everything you can actually do with your switch modules.
If you are able to explain a bit more in detail what you are willing to do with the 2503, I'd be more than pleased to help.
AlessioD
(6,748 Views)
