Switch Hardware and Software
SCXI 1127 Channel Name Convention
I am trying to configure the SCXI 1127 to be a 64x1 mux. How are the channel names oriented? Meaning, if I want to connect "CH8+" to "OUT1+", what "niSwitch Connect Signals.vi" names should I use ("CH8+","CH17" etc).
Jason
(6,556 Views)
When using the SCXI-1127 in 64x1, you cannot route your sgnal to OUT1+. Any of the signals connected to the 64 inputs can only be routed to OUT0+. The 1_wire_Low_ref will be routed to OUT-. CH8+ to OUT1+ is not a valid connection and you will get an error.
If you use DAQmx descriptor the channels are named 1 to 63. See NI Switch help>>devices>>1-Wire 64x1 Multiplexer Topology.
(6,556 Views)
