Switch Hardware and Software
SCXI-1127 OUT0 and AB0
I am currently using multiple SCXI-1127s with the SCXI-1331 TBs. The 1127s are in independent mode. I need to be able to route signals coming in via an input channel to both OUT0 and AB0 at the same time. For example, I need to bring a signal in on channel 1 (+/-) and route that signal to OUT0 (+/-) and AB0 (+/-). My software is currently routing the signals to AB0, but my question is will the incoming signal also be available on OUT0 (switching in the AB0 relay does not disable the OUT0 does it)? The SCXI-1127 independent topology map shows that it will work, but I want to be sure before I make a bunch of wiring changes. Unfortunately, the hardware is not at my location so a prototype session is not feasible. Any advice is appreciated!
(3,940 Views)
You can actually simulate this in NI MAX and try this in Switch Executive with the simulated hardware. Here is a link on how to.
Mathew H.
(3,906 Views)
