Switch Hardware and Software
Simulate NI PXIe 2737
I would like to setup NI Switch Executive before we have the cards delivered.
Is this possible to do for NI PXIe 2737 since I am not able find simulation of this device from NI MAX?
Joms
(5,154 Views)
Joms,
Unfortunatly, these devices do NOT yet have simulation within MAX. For these devices the option available to you would be to create an IVI Logical Name and use that. The Downside is that once you have configured everything as an IVI device, you should continue to use it as an IVI device.
How to create IVI Devices for 2737.
  1. Open MAX
  2. Expand My System
  3. Expand IVI Drivers
  4. Click Driver Sessions
  5. Click Create New in toolbar on right
  6. Rename Driver Session to something useful (ex: "IVI2737DS")
  7. Click General Tab on bottom right
  8. Change Simulate With to Specific Driver
  9. Change Driver Setup to "topology:2737/2-Wire 4x64 Matrix"
  10. Click Software Tab on bottom right
  11. Change Software Module to niSwitch
  12. Click Save IVI Configuration
  13. Click Logical Names
  14. Click Create New in toolbar on right
  15. Rename Logical Name to something useful (ex: "IVI2737LN")
  16. Change Driver Session to name of the driver session you created (ex: "IVI2737DS")
  17. Click Save IVI Configuration
  18. Create a Switch Executive Virtual Device the Logical Name and create routes.
When you get your hardware, you can simply edit the Driver Session to include the device.
  1. Click your driver session
  2. Click General Tab on bottom right
  3. Change Simulate With to "Don't Simulate"
  4. Click Hardware tab on bottom right
  5. Click Add
  6. Give a valid name (ex: "Real2737")
  7. Click checkbox
  8. Change Resource Descriptor to the alias of the 2737 device you want to use.
  9. Add Description
  10. Click Save IVI Configuration
  11. Validate Virtual Device configuration in Switch Executive.
Hope this helps!
Frank,
Software Group Manager
(5,151 Views)
