Switch Hardware and Software
Switch Exec does not show up in MAX for common users
I have installed Switch Exec in a Windows 2000 computer, if I open MAX as the Administrator everything is fine but If I open MAX as a standard user switch exec is missing.  Any idea's?
hrh
(7,335 Views)
Which version of Switch Executive are you using?
(7,322 Views)
Hello Hernanhr,
If you are using NISE version 2.0, then running the attached registry file will update your registry with a fix and you shall have access to NISE from accounts other than Admins. Please back up your registry before you run the attached fix.  In case you run into any problems, you can  restore the older registry file. To back up your registry, go to Start -> Run -> Type "regedit" -> File -> Export.
If you are using a version other than 2.0. Please let me know.
Ayman K
(7,313 Views)
Ayman,
You were right on the mark with your guess of the problem. Your file corrected my problem. Everything is working great!
Thanks for the help.
hrh
(7,298 Views)
