Switch Hardware and Software
Switch Executive 3.6 and LW 2013 SP1
I am using NISE 3.6 and have developed a virtual switch.  I have used NIMAX 15.3 to access the NISE and have ran simulation and verification and all seems to be well.
However, when I use the NISE API in LWCVI, both the NISE open session and close session calls throw non-debuggable exception errors.  In the case of open session if I turn off first chance exception errors I can run to the close session call where a General Protection fault is thrown.
As both calls appear to work when validating the switch (as monitored in NI IO Trace) I  assume the switch drivers are ok.
Has anyone else seen this issue?
Many Thanks,
Steve
Message 1 of 1
(3,459 Views)
