Switch Hardware and Software
Switch Executive virtual device
Currently we call a Switch Executive Virtual device which is made up of several switch cards and implement its' route groups from Test Stand using the IVI-C action and configure it as attached.
What I want to do is implement the route "VSMxxxx" in the same way using the virtual device name directly from Labview. Is it possible? All the control pallettes I have in labview seem to only allow me to set up single routes on sinle switch cards.
Regards and thanks
Matt
(6,300 Views)
Hello, sorry you can ignore this everyone I sorted it out, we hadn't installed Labview support when we installed switch exec, now we have we get all the Switch Exec palette to play with in Labview.
Cheers
Matt
(6,295 Views)
