Switch Hardware and Software
The max. scan delay time the PXI-2503 is capable of
Hi there,
Our application requires the switch card being able to program for extremely long delay time.
Neither the PXI-2503 manual nor the NI-SWITCH on-line help specify this spec..
We're going to make a final decision, so it's kind of urgent; we know that the switch card from Chroma has scan delay time as long as 655.35 sec.
Great thanks!
(6,601 Views)
The maximum scan delay the PXI-2503 will accept is 1.0485 s.
Scan delay is the time between a connection (enter in a scan list) and when the switch sends its Scanner Advanced trigger, 10 mn for this delay is awfully long. Maybe scanning is not appropriate for your application and may be there is better solution to program it.
Regards.
(6,601 Views)
