Switch Hardware and Software
Unable to Remove Switch Executive from System
I'm just trying to remove NI Switch Executive from a PC where it was installed among other NI products.
Using NI Package Manager it's easy to uninstall the product. It's no longer listed there now.
But even after a reboot, it's still showing. How do I clean the PC? I just need NI-SWITCH driver. It's still showing in license manager too. I deactivated the license so it's showing unlicensed.
(4,697 Views)
It seems  that it is part of the drivers, however it might work, to unistall it as a regular software,
https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
Can you give it a try? to see if it is listed on the NI products
(4,656 Views)
Accepted by topic author JICR
JICR,
Can you also do the following:
  1. Go into settings in Package Manager by clicking the gear in the top right
  2. Click "Show full version numbers and infrastructure packages"
  3. Click the "Installed" Tab
  4. Search "Switch Executive" in the top right
  5. Post the list of installed packages
  6. Uninstall any remaining packages if possible
Frank,
Software Group Manager
(4,650 Views)
