Switch Hardware and Software
Unknown error with NI-SWITCH (0xFFFFD5D0)
HELLO,
I'm using CVI 6.0 with DMM 4060 and SCXI 1127 (4 modules), SCXI modules are configured in scan mode and sometimes the function "niSwitch_InitiateScan" returns an unknow error code : 0xFFFFD5D0.
What does it mean? Could I ignore this error code?
My configuration is :
NI-DMM and NI-SWITCH 1.6
NI-DAQ 6.9.2
Windows NT SP5 (french)
Thank you for your help
Jean Philippe VILLEMAGNE
(6,911 Views)
Jean Philippe,
This is an issue that has been seen in NI-SWITCH 1.6. I advice you to upgrade to NI-SWITCH 2.0, which installs with NI-DAQ 7.0.
Let me know if you run into any problem.
Claudia Lorente
http://www.ni.com/ask
(6,911 Views)
Claudia,
Thank you for your answer.
Unfortunatly it's not easy for me to upgrade to NI-SWITCH 2.0 because systems run 24h/24h 7days/7.
Could you tell me if it's possible to ignore this error code or not?
Thank you again
Jean-Philippe
(6,911 Views)
