Switch Hardware and Software
Use Switch Executive to control a switch with a VI for a driver
I have a RF 10x10 switch matrix that I just recieved from a vendor.  The matrix came with a LabView VI for control and I was wondering if there was a way to use Switch Executive to control the switch using the VI.  The matrix as an ethernet and serial connection.
Ted
(5,563 Views)
You can use Switch Executive with third party devices, but you wouldn't use a custom VI. The device would need to be IVI compliant, and then you can use the resources here and here to setup Switch Executive with the device.
- Regards,
Beutlich
(5,553 Views)
