Switch Hardware and Software
VB2010 Examples - niModinst driver is not installed error message
I have a PXIe-1071 with an MXI 8360 PXIe control card and 1x2548 and 1x2576 relay cards installed.
These are controlled successfully using NI MAX.
However, if I run the example VB2010 program examples there is an error related to ni-Modinst not being installed.
Specifically, if I run the "ListDevicesConnectedToSystem.2010" example and select "NI-SWITCH" [or anything] the error "The NI-Modinst Device Driver has not been installed" appears,
and, with the "MakingConnectionsOnASwitch.2010" example the program hangs with the same error.
I've installed the s/w supplied with the switch and updated NI-Switch to 4.8 and also installed the  NISWITCHNETAPI110.exe .
What do I need to do ?
Mark
(6,210 Views)
Hi Mark,
Check out this this post if you haven't already.
Seems like a similar problem has been addressed before.
Cheers.
______________________________________________________
Mark N
National Instruments UK & Ireland
(6,168 Views)
