Switch Hardware and Software
What header needed for TB-2676 ribbon cables?
I'm using the PXI-2576 with the TB-2676.  The installation instructions state that you can buy a kit from NI, or use 8 2x10 .100 pitch ribbon cables.  I chose to use my own assemblies, but then found that the ribbon cable connectors have to have a very low profile to allow the cover to close after the cables are installed.
Has anyone else run into this problem, and do you have a manufacturers P/N that worked to provide the proper clearance?
Thanks.
(7,052 Views)
Hi Dako,
In the National Instruments kit, we use 2x10 0.100 in. Pitch Ribbon Cable Connectors from Samtec, Part Number IDD-10-HG.  You can also obtain the finished 0.100 in. Pitch Cable Connector Assembly from Samtec, Part Number IDSD-10 Series.
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
(7,049 Views)
