Switch Hardware and Software
Where can I find the resource descriptor?
Where can I find the resource descriptor for a particular device.  For example, the SCXI-1129.  I am using the SCXI-Chassis and under the resource descriptor I have entered "SC1Mod3" as the resource descriptor.  Is this correct considering that the 1129 is located on slot 3 of the SCXI Chassis.  I could not find any documentation explaining the syntax on SCXI Modules.  Thanks for your help.
I am using NI-Switch 2.3 and Switch Executive 2.01 with Labview 7.1.
Message Edited by Guy04 on 01-18-2006 02:03 PM
(7,310 Views)
Check NI Switches Help under Programming with NI-SWITCH>>Programming Flow>>initialization
(7,303 Views)
Thank you.
(7,299 Views)
