Switch Hardware and Software
Why I got an error when I continually change channel connection on PXI2530
I use 2530 as a 4x32 matrix. It works well when I use initilize vi -> make channel connect vi and close vi . But when I put make channel connect vi into a loop and change the channel in every loop, it output " the session is not valid " error. the channels are not duplicate in every loop, they can connect well in Switch Front Panel. So what's wrong? need I disconnect before  make new connection?
(7,610 Views)
If I understand your application correctly, you are opening and closing niSwitch session for every connect you want to make. Please try to limit opening and closing of a session to once per application. Doing so will save you significant amount of time as the initialization is not an inexpensive operation time-wise.
Another benefit from using a single session is that errors like the one you've got (invalid session) should be rare and far apart.
If what you're doing is a single open/close session, and you only loop on switch connects, then yes, you will have to perform a disconnect operation before trying to make the new connection between the same two channels.*
 Hope this helps!
best regards,
-Serge
* this of course depends on the topology. In general, matrices will allow more than one connection to a row or a column (but still the endpoints must not be the same), while muxes will not. There are no implicit disconnects in a switch session.
Message Edited by Srđan Zirojević on 09-28-2009 08:23 AM
Message Edited by Srđan Zirojević on 09-28-2009 08:24 AM
(7,602 Views)
yes, I only open and close the session once  in application, the error occur in second loop. my vi is basicly same with example, I just put the connect vi into a loop, but it can't work well, it's very strange, I will check other parts of my application, maybe the error is from other part of my vi.  thank you very much.
(7,594 Views)
Can you post a small code snippet or picture of your code?  Perhaps this is one of those things that's easier to debug if we can see how your code is running.
(7,586 Views)
