Switch Hardware and Software
Why no Switch Executive forum?
Why isn't there a Switch Executive forum? This tool is easy to use for small projects without a lot of complexity, but when the switch numbers get into the hundreds or thousands, things get very complicated. It would be nice to have a forum to ask questions.
(7,629 Views)
kphite -
You are here!
This Switches category is intended for discussions about switch hardware, software, configuration, installation, programming, specifications, application advise, etc. The experts in this community should be able to help you with any of your switch related questions or projects.
- Molly K - NI Web Support Manager
Molly K.
Web Support & Operations Manager
(7,627 Views)
Kphite,
Do you have a specific question about NISE?
(7,628 Views)
Nothing specific. But I like to browse the forums on my lunch break. I tend to learn from seeing others problems and the solutions given.
(7,628 Views)
Ok. Let us know if you encounter any problems. There are a lot of knowledgeable people monitoring this forum.
(7,627 Views)
