Switch Hardware and Software
error7 occured at open/create/replace file
Helo
The vi attached is supposed to log current vs power.im supposed to see current changes on the front panel
under the current(A) string but it remains zero even when the current setting is not zero.another problem is when i run the vi i get the error message
can someone help with this
thanks
(5,725 Views)
(5,717 Views)
