Switch Hardware and Software
how do i make connection between Vision Builder AI to NI-USB6009
I need help ... I am currently completing the final year project ....the idea is developing sub-module for quality inspection using the Vision Builder AI in real time ... the problem arises where I failed to make the connection between Vision Builder AI to the NI USB-6009 ... I would like to sending a signal from the USB out to the PLC (machine) ... can anyone here help me .... .
(6,442 Views)
Set 6009 DAQmx Global Channel in MAX and you'll be able to control it from VBAI under tool menu.
(6,105 Views)
