Switch Hardware and Software
how to use DMM,Source Meter,Swtiching to measure insulation resistance?
1
(6,815 Views)
Fense18,
I cannot tell from your question if you are asking what equipment you would need to make an insulation resistance measurement, or how to make one with instruments you already own.
If you do not already have the instruments you mentioned, please call 1-800-433-3488 and ask for the technical representative from your area. They can assist you in specifying a system that will fit your measurement needs.
If you already own the equipment and want to know more details about making an insulation resistance measurment, please post details about your situation. Some necessary information would be what models of the above mentioned instruments you have, what type of insulation resistance measurement you are trying to make (there are multiple types, according
to this Measurement Encyclopedia entry), and any other information you can provide about the device you are trying to test. I would be glad to give you advice about your application!
Sincerely,
Ross C
(6,815 Views)
